I did everything and figured it out except this part
I have 2011 tahoe with bose sound. Im assuming its amplified. so do I have to follow the steps above? the instructions doesnt clear up if these steps are for non-amplified or all installations.
The GMLAN29-100 comes set up for amplifi ed systems. If the vehicle is not amplifi ed disconnect the 4 pin harness
located between the 30 way and 22 way connector.
• Connect the supplied 4 pin speaker harness and connect the following:
• Connect the Violet wire to the right rear positive wire of the aftermarket radio
• Connect the Violet/Black wire to the right rear negative wire of the aftermarket radio
• Connect the Green wire to the left rear positive wire of the aftermarket radio
• Connect the Green/Black wire to the left rear negative wire of the aftermarket radio
