Get a catch can before any mods.
CHOO CHOO
BackPagePhil
Manheim, Pa
So finally got it installed today and holy crap.
This was ridiculously easy. This IS A FIVE MINUTE JOB. The hardest part was finding a screw to mount it!
1: Tighten all the barbs to the catchcan and use some locktight if you have it.
2: Pull this hose
3: Put the hose clamps on the hose ends and cut the length as needed.
4: Apply hoses to the barbs on the catchcan and tighten.
5: Apply the hoses to the other barbs and tighten. The barb hose in the middle of the catchcan goes to the top barb on the engine.
6: Attach the can to where ever you want.
Here is where I attached mine and the finished product.
Sorry for the dirty engine. :)
Yuko04
"SquareBODluvr"
MN
Took you long enough...[emoji6]
Jiggy-J
shundal
NorCal
Cleaned my home made catch can. Here's after a little over 1600 miles. ImageUploadedByTapatalk1415492839.187995.jpg
PlazaEJ
Installed my homemade catch can, this morning. Looking forward to checking it in a few weeks.
BTW, When I pulled my PCV valve, I noticed the grommet was torn. Gotta pick up a replacement @ O'Reilly's. Be sure to check yours, on older vehicles.
EJ
PlazaEJ
Finally, got around to replacing the PCV valve grommet. It was torn about 3/4 of the way around. So, I'm sure there was a pretty good vacuum leak. I'm hoping this was the cause of the P0171 and P0174 DTC's I was getting when the weather would cool off. Cleared the codes, and will cross fingers they don't return. (I don't feel like shelling out for O2 sensors.
I couldn't resist the temptation to check the contents of my Catch Can.
http://www.tahoeyukonforum.com/forum/attachment.php?attachmentid=30557&stc=1&d=1419104539
OMG, if this what the catch can prevents from being directed into the intake manifold, and subsequently the cylinders, I'm so glad I made and installed mine. This stuff looks a lot like baby $h!t, and about the same consistency. (Dads, you know what I'm talking about.)
That's just condensation in your oil from taking a lot of small trips around town and stuff
Yuko04
"SquareBODluvr"
MN
Heck if i know. Im new. "And your name is"?
Jiggy-J
johnsonwillie199
