alvocado
Allen
I started my suspension refresh plus a few additional items last night with plans to tackle upper front control arms, tie rod ends, differential carrier bushings, sway bar bushings, front and rear shocks, and rear driveshaft ujoints.
The passenger side went well with no issues. The drivers side control arm bolt snapped off and I ended up using a Sawzall to cut it off next to the bushing to get the control arm free. Fortunately I had two AC Delco camber kits with new bolts on hand as both bolts were completely rusted and not suitable for reuse (assuming one didn't break)
The front suspension is finished but I ran into an issue on the "easy repair." One of my sway bar bushing mount bolts snapped off in the frame. I've been fighting it for an hour and no luck. It broke flush on the bottom but I can get vice grips on the top above the retainer nut but it won't budge.The bolt is so rusty I'm concerned it will be really difficult to drill out and save the threads. I'm open to thoughts from others fighting through their rust belt repairs.
Assuming I can get the sway bar back in, I'm moving on to the front diff mounts before bolting the half shafts back in then dropping the driveshaft for the unjoints. I'm already bracing myself for removing those.
