Fox coilovers with xineering magnaride delete kit
olyelr
Elk Rapids, MI
Just installed these yesterday. Fox claims they are adjustable between 0-2” of lift. I had no clue where they were set at from the factory, so I just installed them where they were pre set. Well, it gained just under 2” of height, OVER the 1.5” leveling kit I already had on it. Too damn much, so I will have to adjust them down. I would like to get back to 1.5-2” over the factory height. That was perfect for the stock wheels/tires IMO.
The magnaride delete kit worked flawless. Unplug the factory wiring and plug the little plastic buggers in. Its that easy. Had no codes or anything come up. They seem pricey for what they are, but you dont have a choice I guess. And I know a lot of work went into making them.
olyelr
olyelr
Elk Rapids, MI
So the stock passenger side shock was leaking and making the ride HORRIBLE. I am pretty sure it was basically locked up, not moving up or down... at least that is how it felt as far as ride quality goes.
When I got the factory units out, the passenger side was an inch or so shorter than the driver side. Im thinking it was just locked up in that position.
BlackYukon
I'm kind of a Retard
What's the part number for the fox shocks? Looks pretty good.
Tiki
New aftermarket coils will settle. Put a few miles on them. I would advise running these with a leveling kit, over 2.5” level is going to lead to problems.
olyelr
olyelr
Elk Rapids, MI
This isnt with the leveling kit. I removed the leveling spacers prior to installing. As stated, these gained almost two inches MORE than the 1.5” leveling kit height (without the leveling spacers).
I agree, I would highly not recommend using them set this high.
We are driving it a few 100 miles today. I will check the numbers afterward and post them up.
olyelr
olyelr
Elk Rapids, MI
Alright, got a few hundred miles on the MOM BUS today, with the tires toeing in a mile and a half still. The springs may have settled in a 1/8-1/4 inch or so, but thats about it. It is still over 1.5” higher than it was WITH the leveling kit. As it sits now, the front is about 1” higher than the rear. Still gonna have to adjust them down and inch and a half or two.
olyelr
olyelr
Elk Rapids, MI
Here is a pic of a pamphlet that was in the fox coilover box. Im thinking the part number is the 983-02-086. I know they are the 2.0’s, and obviously coilovers, so...
Christian915
Hi,
This is the same exact setup i am planning on installing. With the front Fox coilovers, do you have to remove them from the car to adjust the height?
olyelr
olyelr
Elk Rapids, MI
Hi,
Well, I just walked in the door from checking on this, as I still need to get them adjusted down a few inches. As far as I know, the answer is YES.
I rented a coil compressor tool from the auto parts store today, which does actual fit in between the coils, however there is simply no room to use it while the coilovers are on the vehicle. My plan was to take the tension off the coils and then try to twist the adjustment “nut” by hand. But again, I will need to remove them.
My other thought was to purchase the Fox adjustment wrench for these units (which is much different then a typical spanner wrench). I found it on line for a measly $7... why the living hell they dont come with the wrench is beyond me. However, it is my understanding that even with the wrench all the tension should be off them, otherwise it could damage the threads. So, yep, gonna have to remove them even with the wrench.
Ugh. Then to top it off, once you remove them and adjust them, it is basically a trial and error thing to get the desired height. This could be quite a time consuming process.
Christian915
It would be nice if we can order them preset at a certain height. How is the ride quality so far? im looking for something not too firm.
olyelr
olyelr
Elk Rapids, MI
The ride quality is great compared to the blown out stockers lol.
It seems like they ride just as good as stock did even with them jacked way up at 2.5-3”. I can only imagine they will ride much better once they are lowered down a bit.
Yes, I too wish they would come preset at a desired height. Im going through hell right now trying to get them lowered down. Took one back out tonight so I could get the spring compressors on there. Once I got the spring compressed down I loosened up the pinch screw so I could spin the nut down... and thats when I realized the nut was cross threaded! How the fawk that happened I do not know, but its all screwed up now. SUCKS.
Adam10532
Overall what is the exact height from top to bottom of the new fox struts compared to your stock struts that you took out?
olyelr
olyelr
Elk Rapids, MI
I didnt take an exact measurement, but it wasnt a whole lot more than the added height from the leveling spacer.
Here is a pic of one next to the drivers side unit (the tops are lined up). Of course the passenger side one was several inches shorter (it was the one leaking and blown out)...
Oh Kee Pah
MAINE
I bet the Suburban is riding a lot better with those Fox 2.0's up front!
I have just over 4,000 miles on my Xineering GM Shock Delete circuits, Fox 2.0 Coilovers up front, 1" spacer in the rear running on 275/60r20 NITTO Ridge Grapplers.
YES - the Fox 2.0 front coilover assembly comes SET OUT OF THE BOX @ +2".
When I first put my Fox shocks on the front of my Tahoe I saw a 3.25" ride height increase. You can believe my surprise as my goal was 1.75-2" of front ride height increase. I understand there is a little settling, but...
So I called Fox. Technically, the 2.0 is "designed" for the Silverado. So, differences in front-end weight on your vehicle vs. a stock Silverado could have some serious effect on the pre-loading of the Fox shock. Also, depending on the age and model of your OE front shocks, there could have been some sagging...
In the end, I decreased the pre-load setting to +1.75" and got the Tahoe leveled out around +2.25" from my original ride height measurements. The ride is hands down amazing compared to the OE magneride control I previously had running on the suspension.
Xineering's circuits make it possible to delete your magneride control and build the suspension of your choosing for the most part. My goal was a 2" level using coilovers vs. a kit. By going with the Fox coilovers I have increased my down travel, improved handling and general ride feeling, improved off road capabilities and increased ground clearance via larger tires via the 2" level up front and 1" rear spacer.
Happy trails!
olyelr
olyelr
Elk Rapids, MI
Happy trails!
Yes, it rides fantastic in comparison to the blown out factory setup.
But, the million dollar question... how the hell did you go about adjusting them?!
Im in a bit of a pickle here because I obviously screwed up one of the attempting to adjust them down.
The tahoe looks great!
Oh Kee Pah
MAINE
We used a wall mounted strut compressor when adjusting the ride level on the Fox 2.0's.
I'm not sure you can do the job correctly on the Fox shocks without it. The wall mounted unit compresses the spring so much that all you do is just adjust the shock via the threads, seriously the shock becomes very accessible.
I marked the original +2" preset thread and then started working from there.
Here's a video that shows the type of spring compressor I'm talking about:
olyelr
olyelr
Elk Rapids, MI
Well, yea I thought that was basically what I was gonna do but using the cheap parts store spring compressor. WRONG.
Big Jim
