Flat Tow 2025 Escalade ESV Sport AWD
Edwardm05
Marine Corps
Curious to know and can it be done.
We are preparing to Flat Tow (4 wheels on ground, TOAD) behind our Motor Coach Allegro Bus.
First concern is the e-brake. How can we disable the electronically controlled Parking Brake?? The RV dealer says that setting up the Escalade for Flat Tow requires a battery disconnect. I think there has to be a better idea because disconnecting the battery mandates that when you reconnect the battery, ALL systems need to be reprogrammed. i.e., Seat Memory, SM Radio and all presets, Google just to name a few off the top.
Is there a means to disable the Electronically controlled Parking Brake??
For reference, we contacted Roadmaster and the other company who provides harness and adapter set-up for flat towing and they do not have a solution due to the 'animated' LED's in the Taillights.
Calling GM/Cadillac as soon as they open in the Morning.
BacDoc
Vero Beach Florida
Definitely contact Cadillac and follow their advice on this.
EV’s are way more complicated and affected by battery disconnect.
Until you get a response from Cadillac, you might want to check the Rivian forums as the IQ is similar to the Rivian R1.
You can also ask AI just to see what it says, but I would still follow the manufacturer advice.
Please post your findings as I am definitely interested in the Escalade EV after my Tahoe gets out of warranty.
Can’t beat the standard 8 years and 100k miles warranty!
ESV, RALPH
flat towing these vehicles generally involves disconnecting the drive line. I don't know if just putting it in neutral is enough
that being said you never ever see them being flat towed, around here anyway I don't know if that is due to law or it's simply not practical.
California requires a hitch be connected (bolted on), then there is the weight problem not necessarily total weight but axle weight. or even total length. never really looked into it too deep
you will occasionally see a small jeep type vehicle being flat towed, even that is a rare bird.
here it is a total length of 65 feet (combined) and not over 102" wide
you must have brake control of towed vehicle of at least 2 wheels if over 1,500lbs
break away system that automatically applies the brakes of the towed vehicle should it become disconnected
light control of towed vehicle
that explains why you probably won't find the adapter, it's more or less impractical, so that makes developing a adapter not worth the money
jerry455
Online owners manual will tell you if it is possible. I don't think it is but I don't know for sure. I assume it is 4WD or AWD. If it has a 2 speed transfer case, it can be put into nuetral.
CrashTestDummy
Pearland, Texas
The owner's manual in the glove box should also give you that information. It is in the owner's manual on our GMC 1500. Most AWDs are NOT dinghy-towable. As Jerry noted, if it has a 2-speed transfer case you can pop it into neutral and drag it, but there are several other things to consider/do.
I've seen Escalades dinghy-towed behind motorhomes, but never checked to see what year/model they were.
fondupot
South Carolina
It's only possible to flat tow if the transfer case can be put into neutral. If I recall correctly, the Escalade has full time AWD, and does not have a select-able 2 speed transfer case like the Tahoe/Suburban/Yukon.
My gut would say it's not recommended, otherwise you will burn up the t-case and transmission.
Page 398 of the owners manual will expand on this in depth. See attached. Downloaded from the Cadillac website.
  • 25_CAD_Escalade_en_US_U_17942216B_2024DEC10_2P.pdf
BadDaddy2003
