- Joined
- Dec 8, 2016
- Posts
- 4,215
- Reaction score
- 5,562
Excellent work!!
What was all the stuff under the rear seat?When I bought it June 2018 100,500mi - 6,685 hrs.
First thing I did was add a cabin filter.
Started pulling wires, many many wires.
Thank you sir.Excellent work!!
Computer Upfitter Controller stuff I suppose.What was all the stuff under the rear seat?
The console was removed from thecopcar when I bought it. I made one from ammo cans. Later I also learned how much wiring had been chopped out.Thank you sir.
They stripped the electronics from the sheet metal center console. Left the laptop mount though.
Yeah, I actually still have all those parts sitting in the bed of my pickup doing no good but taking up space. HahaThe console was removed from thecopcar when I bought it. I made one from ammo cans. Later I also learned how much wiring had been chopped out.
Theothertwin still had a console but no cover for it. It also had the floor plate fir the laptop post.
Pics on my end...?I don't see anything except for your statements. Like has been said, "If there are no pics, it didn't happen".
Lmao. No. That was posted back before he had a chance to post pics of what he was doing, so it was just the explanations and no pics. It’s all good now.Pics on my end...?
What was wrong with the manifold?Replaced the shifter bushing.
Replaced the driver side manifold.
Found the infamous broken exhaust bolt.
Replaced the LCA's.
I was putting in a wideband bung just before the cat. So I unbolted the flange, and the threads on one of the studs came off with the nut and their studs were so rusted in there that the hex on the end of the stud just rounded over as soon as I tried to turn it, so I just went and got a whole replacement manifold. 90 bucks in stock at the local parts store.What was wrong with the manifold?
Replaced the LCA's.
That's not a big deal if they snap off, grind them flush and call it a day. You're going to paint it anyway.that manifold is so pretty.
when i had my engine out, i thought somewhat seriously about removing the heat shield, bead blasting.
then coat with some header paint and reassemble.
in reality, the heatshield bolts will probably break off the moment i try to remove them.
Now it's the only really "old" looking thing about my engine.![]()
AlpharexWhose headlights are those?
I kinda thought they were. Expensive lights! I’m torn on the bulge they have but I hear they work pretty good.Alpharex
