Feeling low on power after mods
Brians4x4
I did a bunch of work over the winter and just now getting to drive it.
2005 Tahoe 4x4 5.3 3.42 gears and 285 wide tires.
I did the following:
BTR stage 2 truck cam, valve springs, and pushrods.
Transgo shift kit with corvette servo and aluminum accumulator.
TCI 2800 stall torque converter.
Volant tube with stock air box. Ported Throttle Body.
****** Aerochamber dumped before rear axle.
Now after all that work I'm only getting 9.9X 0-60 and 18.XX 1/4 mile.
That seems awfully slow to me. I'm wondering if anyone has any ideas what I can look into.
S33k3r
Dallas, Texas
Did you tune your engine after you were done? Also, compare the size of your old wheels/tires to the size of the new wheels/tires. If you went up even an inch, you are going to notice a loss in power -- especially if your tune does not take into account the changes you have made.
Brians4x4
Brians4x4
Yes, I've been street tuning it. I know the tires will slow it down some. I'm going to put the stocks back on before a test and tune soon but I was expecting 15s not 18s.
livingez_123
Sandy, OR
Tall tires with re gearing it will kill the performance. A real tune will help but without the right gearing it still will feel like a slug out of the hole.
exp500
Have you done the required math or are you relying on tribal knowlege for your time/distance/hp/weight/ calculations?
TallHoe 96 OBS
