Fan Shroud Bolts
I noticed my two bolts we're missing that holds the upper fan shroud to the upper radiator support, and there's two other bolt holes that have nothing in them, one bolt hole next to each bolt that holds the shroud in place. Can someone take a pic of the bolts holding the shroud in place, looking from the firewall to the front? I'd really appreciate it. Tia.
This is what I'm talking about.
1_8TTony
They should be 10mm bolts.
And I believe the nuts on the metal are called "Dorman Clip Nuts".......but I may be wrong.
Yup. I found some 10mm's, but is there anything that's supposed to go in the threaded holes next to each bolt? Or are they just empty threaded holes?
Mine looks different- that's where my radiator bolts up.
ScottyBoy
Shreveport, La
GM made those radiator supports for the Silverado, Sierra, Tahoe, Yukon, Avalanche, Burban, and Escalade. And they were all available with different engines and radiators. So that's why there are different holes. Electric fans use one set of holes, and a regular fan shroud uses another set. Then there are 28" radiators and also 34" radiators.
I took another look and figured it out. The blank hole on yours is where the electric fans bolt to, at which point they will cover up the hole that your fan shroud uses now. Look behind the prybar in this pic.
Thank you guys, I appreciate your effort. When I noticed the two bolts missing, needless to say I wasn't happy. I figured if those we're missing, what else did they forget. You never notice something until it's not right. Thank you both! :waytogo:
Do your electric fan upgrade and you'll use those holes as well as cover the others up!
Def gonna do that. Still have to buy the harness. Going with LS1fans. But.... My tuner said he'd tune the pcm to turn it on for free, but if I do the install and he can't do it for me right away, or even if he could, he's almost an hr away, I'd be scared I'd overheat it. Would it be better to pay him for the install so he could tune it right then and there?
Have him turn the pin on first, just in case. The clutch fan will still work until you install the electric one. My pin was turned on for a month before I installed the electric fan.
I asked him a few times and he refused to do it. Said the fan had to be in first, then he'd do it.
What an ass. How does he expect you to drive an hour without a fan? You'll probably be fine, the fans on mine only turn on in the summer. At the worst, you'd have to pull over to let it cool down. But unless it's hot out, you should be fine. That dude is an idiot though.
Yeah, I wasn't too happy with him. I think I'd rather pay someone to activate the fans for me. I hate people doing a favor for me. Never gets done, or never gets done right.
ScottyBoy
Shreveport, La
I had Blackbear Performance tune my Suburban and he said that they always turn the pins on for Efans, even if the customer doesn't request it. Because more than half the time, people end up converting to electric fans. I had no hardcore plans to ever upgrade to Efans until I came across a set in the junkyard for dirt cheap, I couldn't pass it up. Plus the pins were already turned on, so it was a VERY easy upgrade. I did however have to get it retuned and have the turn on temp adjusted down about 2 or 3 degrees because my truck was idling around 212ish. Now it seems to NEVER get over 210.
Oh, and by the way @Tonyrodz I have a factory 06 efan harness for sale if you are interested. Asking $100 shipped.
ScottyBoy
Shreveport, La
The most time consuming part is connecting and routing the wiring. The second most time consuming part is removing the clutch fan. Well, breaking it loose off the water pump really. If you can at least get the harness wired up and routed and secured, and break the fan clutch loose (and just barely snug it back in place to drive the truck). If you get that part out of the way, you should be able to remove the fan shroud and clutch fan and replace it with electric fans in a matter of minutes. Probably faster than it will take him to tune it.
worleytrev93
