gooffeyguy
Tom
After you reload the stock tune, go into it and modify parameters and disable DOD and update the tune.Been there, done that.![]()
What would turning afm back on help accomplish?
Well I, for one, am convinced. I think this also explains the intermittent extended crank that I sometimes experience.
I went ahead and ordered the fuel pump assembly from RA.
I went with the Delphi, as opposed to the "Genuine GM" because the Delphi comes with a Lifetime warranty as opposed to the Genuine GM's 24 month warranty.
I made sure to order the Flex fuel pump.
I guess time will tell if this was the right move.
Now to convince my son to put it in...![]()
Sorry I missed this post. Did you check pressures at the rail?
I think I will go ahead and find my gauge and check the pressures, but will wait until I hear what happens with your pump swap before I do anything corrective in nature.
It is only speculation on my part that something in the image Diablo loads when they turn AFM off might foul up how the Ethanol calc works. The only thing @kbuskill and I have in common with regard to the Diablo units is we both used them to turn AFM off.
I haven't checked pressures at the rail.
I have seen the fuel pressure on the Tech2 and it was always real close to 43.5psi but I never watched it while accelerating hard or anything. I will definitely plug it in and do some observational testing before hand.
After reading the article that James posted, it just makes sense to me now. Knowing that the algorithm takes into account the injectors PWM, that the fuel pressure must be low.
I also have gotten a P1174 that randomly sets once in a while.
Low fuel pressure would also correspond with my truck not starting immediately all the time. Sometimes when I go to start it, either remotely or with the key, the starter motor will engage and the engine will spin over for an extended period of time before actually sputtering to life.
Most of the time the truck fires up almost instantly.
So with having these three symptoms I feel it is probably a safe bet that the fuel pump is on it's last legs. At almost 270k miles it certainly isn't going to hurt anything.
For the record:
I poked around my Tech2 looking for fuel pressure this morning with no luck either.
I use a Diablo intune I3 with the canned performance tune and turn off DOD and remove speed limiter.It is only speculation on my part that something in the image Diablo loads when they turn AFM off might foul up how the Ethanol calc works. The only thing @kbuskill and I have in common with regard to the Diablo units is we both used them to turn AFM off.
My fuel pressure on my Torque app is usually around 43. I've also seen it on the Tech2 around the same pressure.
Under diagnostics, then after entering year and product code....![]()
Intersting.
When going through the selections, select the 6.2l engine just to see if the menu is there
Mine doesn't show transfer case info either, it's AWD and has no electronic switches for it.Interesting result.
It didn't display the Fuel Pump Control Module option, but it also didn't display the Transfer Case Control Module option either.
No error display, but obviously didn't see the Fuel Pump Control Module.
I suspect the Fuel Pump Control Module is reserved for GM's rich customers only.
