Ethanol percentage flex fuel
W
wsteele
After you reload the stock tune, go into it and modify parameters and disable DOD and update the tune.
I am just turning AFM back on, no tune per se.
St. Louis
I just saw that is what you basically did, and not using the diablo tune
W
wsteele
What would turning afm back on help accomplish?
It is only speculation on my part that something in the image Diablo loads when they turn AFM off might foul up how the Ethanol calc works. The only thing @kbuskill and I have in common with regard to the Diablo units is we both used them to turn AFM off.
W
wsteele
Well I, for one, am convinced. I think this also explains the intermittent extended crank that I sometimes experience.
I went ahead and ordered the fuel pump assembly from RA.
I went with the Delphi, as opposed to the "Genuine GM" because the Delphi comes with a Lifetime warranty as opposed to the Genuine GM's 24 month warranty.
I made sure to order the Flex fuel pump.
I guess time will tell if this was the right move.
Now to convince my son to put it in... :buttkick:
Sorry I missed this post. Did you check pressures at the rail?
I think I will go ahead and find my gauge and check the pressures, but will wait until I hear what happens with your pump swap before I do anything corrective in nature.
kbuskill
NE. FL.
I haven't checked pressures at the rail.
I have seen the fuel pressure on the Tech2 and it was always real close to 43.5psi but I never watched it while accelerating hard or anything. I will definitely plug it in and do some observational testing before hand.
After reading the article that James posted, it just makes sense to me now. Knowing that the algorithm takes into account the injectors PWM, that the fuel pressure must be low.
I also have gotten a P1174 that randomly sets once in a while.
Low fuel pressure would also correspond with my truck not starting immediately all the time. Sometimes when I go to start it, either remotely or with the key, the starter motor will engage and the engine will spin over for an extended period of time before actually sputtering to life.
Most of the time the truck fires up almost instantly.
So with having these three symptoms I feel it is probably a safe bet that the fuel pump is on it's last legs. At almost 270k miles it certainly isn't going to hurt anything.
kbuskill
NE. FL.
In my case I am actually running a custom tune from Lew @ Diablew, not just using it to turn off AFM, although that is one of the features in my tune.
W
wsteele
Reading my shop manual on the subject, it says 50-60psi, so if you are getting 43.5 that definitely is a problem and would call out a pump replacement.
If you happen to be using the Tech 2, could you take note of which menu and section you are at when you are reading the fuel pressure and post it back up? I looked and looked and couldn't find it anywhere. I suspect the 2007 model year doesn't communicate between the PCM and any fuel pressure sensor (maybe an internal sensor in the pump itself that the pump uses) as when I did the "all sensor" read on my dongle scanner, it lists 155 different sensor values, but fuel pressure isn't one of them. The shop manual calls out using a manual gauge on the fuel rail to test pressure, so again, I think the 2007 model year didn't get that ability, which is actually quite surprising giving how important fuel pressure is in an EFI engine.
Anyway, anxious to hear the results of the pump swap. I will check my pressure at the rail with a gauge here in the next day or so and will report the results.
St. Louis
I use a Diablo intune I3 with the canned performance tune and turn off DOD and remove speed limiter.
St. Louis
My fuel pressure on my Torque app is usually around 43. I've also seen it on the Tech2 around the same pressure.
W
wsteele
What page is your fuel pressure reading located on your Tech 2? Take a picture of the Tech 2 screen and post it up, I can figure it out from there.
According to my GM shop manual, a fuel pressure at the rail (as measured with an external gauge) should be between 50-60.
St. Louis
Under diagnostics, then after entering year and product code....
W
wsteele
Must be a 6.2L versus 5.3L or model year thing.
Mine doesn't have the "Fuel Pump Control Module" page.
Maybe I don't even have a Fuel Pump Control Module.
The fuel trim display is what I have in the video.
W
wsteele
Intersting.
When going through the selections, select the 6.2l engine just to see if the menu is there
Interesting result.
It didn't display the Fuel Pump Control Module option, but it also didn't display the Transfer Case Control Module option either.
No error display, but obviously didn't see the Fuel Pump Control Module.
I suspect the Fuel Pump Control Module is reserved for GM's rich customers only.
St. Louis
Interesting result.
Mine doesn't show transfer case info either, it's AWD and has no electronic switches for it.
It think it might have to do with the model year why yours doesn't have that menu option
BadDaddy2003
