DRL to delayed turn signal
Tyler Gober
Booneville
so I'm wanting to turn my DRL(the ones next to my turn signals) into another turn signal. One that blinks when the actual turn signal isn't. Like
Drl on > turn signal off
To
Turn signal on >drl off
And back and forth until I turn my signals off
How can I do this?
89Suburban
Bull in the china shop
SE PA
Just like the old square body Chevy truck alternating turn signals right? It’s gotta be grounded a certain way. Try looking up a turn signal schematic for like an 88-91 Suburban.
Tyler Gober
Tyler Gober
Booneville
Yes i do believe so and alright ill look that up
BG1988
To
How can I do this?
with a relay and duo 3157 socket
you will want to use the dimmer filament for the DRL
you will need a 8 pin relay for that
photo source
f150online.com/forums/illumination-lighting/484446-3157-194-switchback-led-bulbs-logo-courtesy-lights-2.html
this is for a switch back bulb
BG1988
That'll work i appreciate it
i suggest getting socket extensions so it can easily be converted back so you don't have to cut the factory wires harness
bit OCD about cutting up the factory wires harness.. ;) unless it's positively necessary
in this case it's not since they sell wire socket extensions that can be chopped up .. unless you are going to go all in soldering them and shrink wrap etc..
Tyler Gober
Tyler Gober
Booneville
I'm the same way. I got the male and female connectors for the radio wire harness
caprajohn
