Dome and Map lights
Symba_The_Lyon
Hello i am new and i have a 1996 Tahoe, lt, 2 door, and the map light and the dome light's will not turn on i have changed all the bulbs and still nothing any one have any ideas on how to fix this? looking foreword form hearing from you. :Handshake:
Symba_The_Lyon
Symba_The_Lyon
Yes i checked the fuses and there all good none are blown and the dome override button on the head light switch dos not do anything except turn the courtesy light on in the floor board and the doors,
Donnie Yukonie
Yates Caretaker
well the map lights are independent of the dome lights and are turned on by a switch. so when you press those buttons nothing happens?
Symba_The_Lyon
Symba_The_Lyon
If you are talking aboght the map light buttons and in the back reading light they do nothing you you press them also checked all of the bulbs none are blown,
Donnie Yukonie
Yates Caretaker
fuses good, bulbs good have you checked the actual socket to see if its getting power with a voltmeter?
Symba_The_Lyon
Symba_The_Lyon
No i do not have a volt meter i am going to half to buy on during the weekday, So if there is power what do you think the problem is? & If there is not power what do you think?? Thank you for all you're help man.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
all those lights run of the same fuse #3 CTSY 20 amp. can i assume your parking lamps and the headlight circuits work correctly? if so the problem is in the fuse block or that fuse or a short piece of wire from it. those circuits plus fogs if you have them are fed by the same wire going into the specific supply bus. if all those circuits are out there is a 50AMP ****-fuse under the hood in the power box labelled Lighting.
Symba_The_Lyon
Symba_The_Lyon
Yes the parking lights and the headlight work, & also don't have fog light, lol Do you think its the ground? i have read on other forums that it might be that.
Donnie Yukonie
Yates Caretaker
try swapping out the fuses just to be sure or make sure they have good contact points I.E no rust or corrosion
stereodesigner
If you've checked all that you may have to follow the wires from the killswitch/fuse box maybe a wire got cut somewhere on accident
Sent from my DROID X2 using Tapatalk 2
SunlitComet
OBS Jedi-Do Good
there are as many as four ground locations at play here. but they all go thru one point. that point also carries ground from other systems in the cab like radio, a/c controls, Airbags, instrument lighting, instrument readings among some other things. if it is just the lights i would check the splice S242 "I/P harness, approx. 8 cm from headlamp dimmer switch breakout toward i/p cluster" it will be an orange wire breaking out into 4-5 more orange wires. any of those wires should constantly have voltage on them.
Symba_The_Lyon
Symba_The_Lyon
I just replaced the fuses still dos not work but i just found out there is no power going to them i just took the ceiling organizer off and there are one pair of black and orange wire starting at the front map light's an d it ends before the first dome light and the two dome light's branch off in to the wiring harness, what would be the first few steps i should take to fine out why there in no power?
SunlitComet
OBS Jedi-Do Good
you need to find out why the is no power available where the fuse goes. until you get power at the fuse connections the rest is irreverent at this point.
Symba_The_Lyon
Symba_The_Lyon
There is power at the curtsy fuse #3 I just blew it trying to run a wire from the mirror light in the visor what im not under standing is i have power to the mirror in the visor, in the doors, and also the curtsy light in the floor board which all run of the same fuse so that means that i should have power in the wires in the ceiling, lol So i guess what im asking now is how to get power back in these lines :lol2:
SunlitComet
OBS Jedi-Do Good
you will wont to look at that splice i told you about earlier. also check for a dirty or disconnected wire connector at the convenience center it feed the roof.
Symba_The_Lyon
Symba_The_Lyon
I have a update for you guys i have all the light working in the cab :signs1:
JPeter
