Front map light button broken
th3 shifty
Utah
Hey guys, anyone have a tutorial or a post on how to fix the front map lights? My driver side one, the button pushed in and won’t retract. I can feel that the “spring” or whatever it is, is no longer functioning. Would like to fix it if there is already someone out there that has a fix
exp500
Clean the mice out is 1st step whichever way you go! New/used.
They like to crawl up A&B pillars.
Can you put a small suction cup on the depresses plastic surface and pull the switch back to is resting position? That would be a troubleshooting starting point.
th3 shifty
th3 shifty
Utah
It’s loose actually, it now falls back into its position at times but you press it and it’s like nothing behind it. So it’s broke somehow. I guess a trip to the pull-a-part is in order
brice715
