DIY: Tahoe Rear Brakes
mikewayne
Thanks for such a nice informative post along with explanation in the forms of images that makes us easy to understand all the technical terms as they seem easy to understand due to the images.
a4edwin
ny
did mine today awesome only thing i had a 4inch c clamp little more diff but still got it done
Wake
Stafford, VA
This is the parking brake adjuster...
GM were dumbasses and didn't make it auto adjusting, nor even externally adjustable.
As seen in this pic, you would turn the upper edge of the star wheel toward the backing plate to tighten the brakes.
Are you sure there's no external adjuster?
I just did this today but took it all down as you showed so I could inspect the shoes, axle seals, and backing plates while I was at it. I ended up cleaning things up and using rustoleum on the backing plates that are starting to show some rust.
My previous SUV was a Trailblazer with the same type of e-brake setup. The adjustment was done from the inside of the vehicle at the parking brake lever. There was a ratcheting mechanism that you depressed with a screwdriver, then cycled the handle three times repeating as necessary.
BlueMeanie
I have a question about something....the pin that you remove to get the rotor off...do i need to put it back on once i place the new rotor on?
sureshot
Thanks for the very helpful post.
My friend's Tahoe E-brake was not holding, and I had no idea there was a drum brake inside the disc brake.
FishinCricket
GMC Salesman
The Ozarks
Awesome info!
---------- Post added at 11:58 AM ---------- Previous post was at 11:45 AM ----------
Did this post lose anybody else?
mitchievu
