Denali grille emblem
01pewterz28
Central Florida
I could not find the answer but I picked up an used OEM 18-20 Denali grille w/out the GMC emblem. My question is will my 18 GMC emblem from my SLT fit the 18-20 Denali grille or do I need to go order a new emblem..
thanks in advance
Big Mama
Virginia
Welcome to the forum from Virginia. I’m not much help on this but you might see how it attaches to your old grill and look for the same hardware or mounting points on the new one. If there aren’t any and you need to drill holes you should be able to make it fit. Just a guess on my part.
CMoore711
It should be the same and will swap over from your SLT grill to your Denali grill no problem.
01pewterz28
Central Florida
Thanks I will find out this weekend I figure it should be the same but it's GM you never know... looking forward to installing the grille searched for a year to find out that did not cost me an arm and a leg...
STORMIN08
tape measure, dont worry about mounting studs, 3m double side emblem tape is some good stuff...just cover the entire rear area
01pewterz28
Central Florida
well I decided to go ahead and do the install after work took about an hour. The grille emblem is different for sure just need to see how to make this fit now. The SLE/SLT grille mounting area is flat vs. the one on the OEM Denali grille. I have the emblem on but it is not flush.
01pewterz28
Central Florida
pretty sure I have found the issue the emblems are the same but the denali grille I have is missing the black plastic raised piece that goes in the grille area on the grille and the GMC emblem attaches to it. See attached photo of a OEM Denali grille I saw on Ebay you can see the black area under the emblem.. Mine did not come with that piece the owner kept the emblem w/ the black piece.
01pewterz28
Central Florida
Does anyone work for a GM dealership see if I can purchase that piece seperate or if I can order the emblem and the piece comes with it..thanks
CMoore711
What does the back of your black GMC emblem look like?
01pewterz28
Central Florida
this is the back of the emblem it's the black mounting plate that I need that is missing. The Black mounting plate attaches to the grille and the emblem ataches to the mounting plate.
STORMIN08
will it sit flush if the alignment tabs are gone ???
like stated, i regularly use 3m double side emblem tape...but make sure to cover the entire area so dirt and debris are locked out of the rear area causing failure from moisture
01pewterz28
Central Florida
It might if I add 2-3 layers of 3M tape might see if I can locate a used emblem to try before breaking the tabs off mine other wise no way to attach it.
01pewterz28
Central Florida
Where did you get your black GMC logo from?
I painted it I took the letters off (easy to pop out the emblem masked off the letters and shot it will 6 coats of glossy black.. $10 vs. GM's 120 for front and rear replacements and black vinyl does not work too well after washing and in the Florida heat.
justinakay79
