There is nothing to seal that i know of.
I can actually say with confidence that this bolt holes are on the working side of the manifold, as pumping smoke through the throttle body hole causes it to billow out of the bolt hole without a bolt thereThere is nothing to seal that i know of.
Im at a loss here. I have R&R many LS intakes. I can not ever remember seeing a grommet on any intake hold down bolt.
What am i missing?
Nope. That picture you show is a valve cover bolt and does have a grommet, but it's a different size bolt and different size/shape bolt...The bolts with the grommets on them are actually valve cover bolts. Take the grommets off and its the same as manifold bolts.
I'd have to disagree. I broke a manifold bolt in the past and used a valve cover bolt minus the grommet as a replacement. Besides the grommet the bolts are identical. The bolt is still in place.Nope. That picture you show is a valve cover bolt and does have a grommet, but it's a different size bolt and different size/shape bolt...
I guess that's possible if the correct bolts are there, which makes my stomach turn a little, but since my last valve cover hasn't quite gone back on yet...I'd have to disagree. I broke a manifold bolt in the past and used a valve cover bolt minus the grommet as a replacement. Besides the grommet the bolts are identical. The bolt is still in place.
