akbrener
2008 Tahoe 2wd with about 150K on the clock. recently the rear brakes started creaking when pressing the brake pedal. If I am stopped and push on the brake pedal you can hear a hollow creaking noise out back. if you lightly push the pedal its quiet, but as soon as you press hard, as in pulling into a parking spot or at the drive-thru window you can hear it. creaks as you apply and release the pedal.
Already pulled the pads off, cleaned them and re-greased the pins. It is hard to pinpoint the exact location where it is coming from while laying underneath.
Anyone else had this happen? only thing I can think of is that it is some bracket on the rear axle or possibly one or both rear calipers needing to be completely replaced.
