crankin torsion bars
Arctic-Rodz
RGV Texas
if im not mistaken, worse that could happen is turning them to the very edge and putting more stress on your ball joints.
not sure what the "limit" is though
navy34
You can crank, just make sure you dont too much. Check the CV angles, dont wanna be too extreme with those..
navy34
I ran 285's with just cranking my keys to level, which wasnt a whole lot. You could go that route. I personally dont like wheel spacers, not the safest idea imo.
Like DaRosa said, you can clear them, but youll probably have to trim a little if you dont want to rub while flexing.
theT-hoe
theT-hoe
Henderson,TN
yeaa i just want it sittin level and able to run 285's. what yall think the widest 285 i could do ?
polobuds
East Bay, CA
if I'm not mistaken, 285 refers to the tire width. It depends on the tire, but 285s are about 11.90" wide. For comparison sake, a 285 nitto trail grappler is 11.93". A 295 nitto trail grappler is 11.97". A 305 nitto trail grappler is 12.60".
Frankhenrylee
Little Rock, Arkansas
2" wheel spacers will make it more likely to rub. 2" rear coil spacers will make it too tall in the back. At the most 1" spacers on wheels and probably no spacers on rear coils if you want it to sit level without cranking the torsion bars all of the way. Just jack up the front to where you think you want it at and look at your CV's. I'm not sure what safe would be but you want to keep it to a minimum. Too much crank and tires wear badly, alignment doesn't stick, CV's give out, and you lose ride quality. I think the tallest tire you can go without alot of crank is a 285/70-17 or 285/75-16, and thats pushing it. I'm going to crank mine a little and go with either 275's or 285/70-17's. You'll need to trim here and there as well.
beachrig
North Carolina
285's
I am on my second set of 285/ 70 17's first set were destination at's looked good but only got 40k out of them. I went back to Mich A/T2's however they rub just a little, where my Destination at's did not. However I just blew out the upper control arm bushing on drivers side so over the next few week's I'm installing 2 new mevotec control arms with new bushings, 4 new Bilstein shocks and am going to crank the bars to get .5-1" hopefully. Everything I have found has said its ok to do just not too much i.e CV angle and make sure you leave some threads. If you want I'll post some pics on the progress.
cliffordz71
I've got Ford torsion keys installed and cranked to level 2" rear coil spacers. All sitting on some 295/70/17 Toyos. Rides like shoot unless you get aftermarket shocks. Also be careful cranking your keys at all. The more you crank them, the worse your CV angles=more stress=MUCH weaker. I'm just telling myself that I will have to start replacing parts a few miles before I would have without cranking them.
beachrig
North Carolina
I agree, I'm just trying to level mine out and get it to stop the rubbing. It only rubs when I'm backing up and have the wheels turned. I'm hoping with the new shocks maybe it will eliminate some of that too. But the Bilstein people said that the normal shocks would work with a 1" crank. So I'll probably do all of it and if I don't like it then I can keep the same shocks and just come back down with it..
Clifford your z looks great, I really think these trucks look best when lifted and the stock rims are kept..
ScottyBoy
Shreveport, La
What about cranking them on a 2wd? Does it still stress the suspension? Or is it the CV axles on a 4wd that are the main thing stressed when cranked? I am looking for about 2 inches possibly 3 inches of lift, can that be obtained by cranking and no worries about damaging the suspension because its cranked?
beachrig
North Carolina
Don't know never had a 2wd!
The only thing I have ever heard is that it adds a little more stress to the ball joints (which I'm replacing now and is not that hard to do if you needed to) and if you over crank them it can screw up the cv joints due to the angle. But again I'm only going up a .5-1" to level it out a little. From what I understand if you are going up to 2 etc. the best way is to do it is with the ford keys, new shocks all around and spacers in the back. But again that's just from what I have read.
ScottyBoy
Shreveport, La
My back sits about 2-3 inches higher than the front. So I want to just lift the front to get it level, or at least a lot closer to level.
dizhai
