Coolant Loss
jmildoc
Indianapolis,Area
I am not sure if I lost coolant or just a sensor is acting funny. Wife left for the store then called and said the message center said low coolant... I told her to come back and I put about a cup of coolant in and the light went out, it didnt even seem low. What could this be? Should I do a drain and fill to be safe or what?
Any help is appreciated....
Modded
That Guy
It was probably low if it turned off after filling.
Did you see the level below the mark on the tank?
Sepiroth
I am here
Kouts, In
Honestly, the coolant system is a closed system. That being typed, anytime you have to add coolant, you're losing it somewhere. Now where, or how long it's been leaking, I dont know.
The only way to find out is to have a coolant system pressure checked perferomed. This should be done on a cold and warm engine. This will most likey find out where your leak is.
It could be such a small leak that this is the first time its been low enough on coolant to let you know.
jmildoc
jmildoc
Indianapolis,Area
so there is no possible way that maybe my cap is worn out and it is evaporating or something. I mean I only added like a cup maybe less!!!
Sepiroth
I am here
Kouts, In
Sure, a bad cap is a possible. Chances are that if indeed the cap is bad, you will notice some sort of staining from the coolant leaking and then drying, either on the radiator of de-gas coolant resovoir.
Sepiroth
I am here
Kouts, In
If your reservoir is nasty, the rest of your cooling system looks as nasty. Thats why I hate DexCrap.
Rivieraracing
Try taking the resevoir off and take some simple green and a scrup brush and go to town, something that will get inside the resevoir without damaging it!! Should clean it out pretty good!!
OKLAGMCRUISER
Need drop...send $
Kiefer, OK
a cup of coolant may or may not be enough to have the level to your hot level in the reservoir. all that a cup may have done for you was put enough liquid in the reservoir to float the switch up to turn it off. you CAN put dexcool back into the truck OR you can do a full system flush and go back to another antifreeze, but you'll have to make sure all of the dexcool is flushed out of the radiator, engine and heater core....ie the entire system.
Pat
Sepiroth
I am here
Kouts, In
If you have DexCrap in there now, you might as well stay with that.
If you've done a complete flush, I would go with the G-05 yellow coolant.
Sepiroth
I am here
Kouts, In
IIWY, I would just add DexCrap. The way you described the degas bottle, tells me it's Gen1 DexCrap.
tybardy
everyone needs a Hoe
Gilbert Arizona
its most likely dexcool... thats what GM uses these days, its what i have... i have no problems but i also have no education on the matter... whats the problem with DexCool guys? why is the yellow shit better or is that just personal preferance?
I have a VERY small leak under my throttle body somewhere (not the TB coolant bypass either) and i have to add coolant in about twice a year. I just add 50/50 DexCool.... i wouldnt be apposed to doing a flush and changing fluids if i thought my truck would benifit from it though
Modded
That Guy
How will someone flush out all the coolant, is there liekea drain plug?
Just wondering.....
jmildoc
jmildoc
Indianapolis,Area
you can buy a bottle of radiator flush that cleans it out....
My fluid is Yellow.... So I guess I can use any kind. I bought a tester and am going to see if its still good...
ZaZaZazzels
