Coolant Leak - Have Removed Water Pump Now What?
campbmic
About a month ago I posted about a pretty serious coolant leak that was leaking rapidly on my 2003 GMC YUKON XL...
Images: http://imgur.com/a/RrL1d
Video: https://www.youtube.com/watch?v=_3CTl16RPkc&feature=youtu.be
So I'm now 99% sure that the leak is from the water pump. I removed the water pump tonight but don't know what to do next. I dont want to buy a new one if the original water pump is fine. I inspected it and didnt see any cracks or major issues.
Could the gasket have failed? Could the water pump have just come loose? Should I just clean everything up, buy a new gasket and just put it back on? Or is this just a waste of time?
Also I broke this T-connector what is it called? THE LINK IS BELOW VVVVVV
http://imgur.com/U2vOnka
Thanks everyone!
FamilyTruckster
Awesome Dude McChainsaw
Detroit-ish, MI
its not all too rare to come across water pumps with bad pressings (some of the nipples are press fitted in when manufactured), though you do see it more on the larger inlet and outlets... i've even seen trucks with a puddle of coolant around an inlet just sitting in the lot (before the truck was even sold!) - again, bad pressing. Unfortunately, to my knowledge, the "fix" is to simply replace the unit entirely. Luckily, they are not all too expensive, readily available, and not too difficult of a job...
---------- Post added at 03:23 AM ---------- Previous post was at 03:20 AM ----------
also, not sure what happened, but the linked picture is not of a "T" (at least i'm not seeing it...???)
---------- Post added at 03:27 AM ---------- Previous post was at 03:23 AM ----------
this "bad press fitting" issue isnt exactly "visible" either... you wont notice a gap or loose fitment... if that makes sense. You just see the coolant passing/puddling etc
ccapehartusarmyINF.(ret)
Gilbert AZ
if you got the water pump off put install a new one there cheap i got mine on amazon for 60 bucks
especially if you got alotta miles on yer rig
plus im almost certain if you re use the old puimp itll start leaking again pretty quickley
ezdaar
Chat Troll
Redneck central, Aka Houston
Just hit a orileys pr autoparts store.
Those plastic parts commonly break. They will have replacement.
If not hit a dealership. You will definatly get it there.
afpj
The hoses to the y ( or t) connector look kinda old. Maybe time to replace hoses too. You may not be able to tell bearing failure just by looking at it. Replace pump & tstat
C
campbmic
Thanks for the advice! Will buy new one! Also, I wasnt able to remove the fan when I took the water pump off. I kept turning the bolt behind the fan but it never came undone. I went to autozone and they gave me a tool but all it was, was a big wrench? Any tips on how to get the fan off?
Thanks
01ssreda4
The pump has an internal seal and bearing. On the bearing side (dry) there is a weep hole. If the coolant (wet side) gets passed the seal, it contaminates the bearings. If there was no weep hole you'd never know this happened until you had a castrophic bearing failure which would leave you stranded. The weep hole allows you to slowly lose coolant over time allowing you to see the problem before the failure that leaves you stranded. Look for signs of staining around the bottom of the pump, it usually isnt hard to track down once you know where to look.
Gilbert AZ
yes thats it i remembered when i replaced my water pump like 3 years ago on my tahoe there was a specific reason why you had to replace the whole pump and not just the gaskets i just couldnt remember why
---------- Post added at 05:04 PM ---------- Previous post was at 04:58 PM ----------
Thanks
okay heres how you get the fan off go get a big adjustable wrench if you have
one like a big one and then adjust it and put down on that bolt that holds the fan clutch on and put so that adjustable wrench is standing straight up
then take the heaviest hammer you have i used a small sledge hammer
and give the end of that wrench a good wack and you should break that nut loose in one wack
dizhai
