Blown Away By Fuel Tank Pressure
01Tahoe175K
New subscriber today. This is a great resource. I have an '01 Tahoe with 175K miles. The check engine light has been on for awhile now. I had my shop check it and they said that it was a problem with the fuel evaporation system. He did some preliminary checks and couldn't find any problems. Now, when I take the fuel cap off to gas up the pressure inside the tank is a little scary. I have to vent it off slowly, otherwise it will try to knock the cap out of my hand. Has anybody else had this problem, or have any suggestions for a cure?
01Tahoe175K
Fuel tank fills with no problems.
---------- Post added at 09:52 AM ---------- Previous post was at 09:47 AM ----------
The fuel caps don't vent to the open air anymore, do they? That would seem very "un-green". The cap seems to work the same as it always has. How would one go about testing it?
Goldcuffs
Most common problem is a vent solenoid. Make sure you get a GM replacement not an aftermarket.
Walynw
I just replaced evap solenoid with one from oreilys Light went out thought things were good. Wife called said cap had pressure and wouldn't take fuel but very slowly
brice715
