BacDoc
This is good advice!Make sure your battery is bad before you replace... and then if you go new.. test it. don't just pick up any old battery without a test.. below is a tester that determines cranking amps.. useful. $20. Amazon.
I have tested a few batteries from Walmart and they were mostly good but using the voltmeter I found a lot of variations.
I was surprised that there was a significant difference in voltage when I put the meter on them.
