Any one run no rear sway bar?
FLETCHxj
I'm fixing to order a RCX 6'' lift and was wondering if it's ok to run no rear sway bar. I remember I removed mine in my old jeep and it didn't effect anything but want to make sure it's safe to do in the tahoe before I pull it off and put anyones life at risk
rmodel65
a lot of cars and trucks dont come with a rear sway bar...youll be fine im sure
_Dylan_
STAY FROSTY
I took mine off because my bigger spare wouldn't fit with it on. Mine isn't lifted though.
I haven't noticed any difference. The front bar is much more important than the rear.
Blazed
Accepting Donations
A big ass tahoe going down a windy high way and no sway bar is something I wouldn't wanna experience. I've had a broken endlink on my rear sway bar and it wasn't fun
Goodinblack
I Like Tacos
Dirty South
Most all the trucks from the 80s 90s 2000s did not have rear bars.
I would keep mine though
Goodinblack
I Like Tacos
Dirty South
These were leaf sprung trucks weren't they?
I think that plays a part
Yes.
Although on my old excursion it had rear leafs and added a Helwig.
I would always run one if they made it. :)
Blazed
Accepting Donations
Hmm well maybe he will okay but I know for sure I would never do it. The winds takes these trucks even with the sway bar
_Dylan_
STAY FROSTY
...you know wind resistance isn't the reason for sway bars right?
Blazed
Accepting Donations
I know that's not the use I just know it helps in that situation and it would be my worst worry. Because I can slow down on turns by my own will but I can't control the wind while I'm on the highway.
livingez_123
Sandy, OR
Off road and no sway bar = :)
On road and no sway bar = :(
And BTW, both of my 1 ton dually's had rear sway bars.
bowtiefreak
No Quarter
Near Philly
My suburban has one. Two door tahoes do not come with them. needless to say I still do not have one
HortonHiresAHoe
Mt. Juliet, TN
I have a 2dr w/ 6" lift and 35's. Left the rear sway bar off when I did the lift and can't tell a difference... rolls down the interstate and back roads just fine
kcb37
Wind may not be the reason for the sway bar but it does help.
I would agree, not something I would take off, if anything I would upgrade.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
LEAVE IT ON! These vehicles can rock just going over a speed bump slowly at an angle and as they get loaded with weight the effect can intensify. Doesn't matter if wavy street or highway lanes the 4dr and and burbs and trucks need them and they are there to help handling.
99lifted
I have a 99 Tahoe 4door just got it and theres no links in front or rear sway bars....it is lifted bout 6 to 8 inches with cst lift...can I run stock sway bar links I cant fine extended front links anywhere. I know i need extended rear links any advice is greatly appreciated....and no the 30 mile drive home with it with the sway bars not hooked up....was no fun and scary
veteran111
