Any guess as to what will hit next?
Doug118
Anyone care to gues what will be the next issue I run into? Rear sway bar already has to be removed. Plenty of room between the axle and frame now
Why does the sway bar have to be removed? That’s gonna make it squirrely as hell. DJM makes a set of end links that let you move it to the passenger side an inch so it clears the panhard bar mount.
Doug118
Doug118
truck is so low that the sway bar goes between the shock and panhard bar mount and it just doesn’t fit even with the offset end links
BlacktopBandit76
