Any aluminum radiators that don't crack annually?
ls1frc
Hello, I have a mishimoto aluminum radiator. The first one cracked within a couple of months. The second one lasted about a year and a half. I am tired of spending money on the shipping for the warranty and the extra money each time I have to change the coolant.
I read reviews of cold case and it seems they are even worse
I will go back to stock if I have to, but wanted to see if there were other options first
Geotrash
Dave
Richmond, VA
Long time, no see - welcome back! I'm still running my Cold Case that I installed with my cam swap 2 years ago. No problems so far and about 20K on it since then. If I had it to do again though I'd get a stock Denali radiator (1.3" thick core). My tans cooler is relocated to below the bumper on my 2012, so it's no longer dumping heat in front of the rad.
L
ls1frc
Haha thank you
My truck is still going strong on the original 6.2 swap, it has about 180k on it now and around 40 or 50k on the engine, it is an absolute work horse
However, I am so tired of this reliability issue
I read cold case you have to trim the tabs, is that true? Perhaps I will just get the denali radiator then. Is that different than the SLT 5.3 radiator that already came with oil and trans cooling?
I plan to tow my 2016 corvette (around 3300 lbs) with this truck this year, so I need something that cools well and is reliable
I see AFE makes one, I have always liked their stuff
Geotrash
Dave
Richmond, VA
Yup, still have to trim the tabs AFAIK. I did anyway unless something has changed since then.
Yes. The 5.3's have a 1" thick core, I believe. And every parts house specs that radiator for the 6.2 Denali's also, but the factory Denali radiator is actually 1.3" thick. I know this because I just replaced the one in my 2007 with what was supposed to be the correct radiator for my truck, but it wasn't. So I'm running that one on the 5.3 rad for now and I ain't happy about it.
L
ls1frc
Okay thanks for the information
I wonder if there's something with the truck that's causing it to crack radiators. Too much torque?
Sparksalot
Bastrop County, Texas
Haha thank you
I put a Coldcase in thecopcar a little over a year ago. No issues with it. I didn’t have to trim anything. It appears the end tank design was revised slightly from earlier versions.
Geotrash
Dave
Richmond, VA
It's possible and would explain why some cold case radiators are cracking and others aren't. I was careful to remove enough metal from my mounting tabs so that there was no direct metal-to-metal contact between the steel frame of the mounting area with the tabs of the radiator, so that the rubber isolators could do their job. I've also read that poor or weak grounds can trigger electrolytic corrosion in aluminum radiators. So if the radiator is grounded to the steel frame through direct contact, it can cause problems.
i bought the coldcase and they have updated the design, nothing needed to be trimmed. However it did leak within 30 days so I returned it and went back to my stock sized denali radiator
the radiator shop here in town that has been in business for probably 100 years say the aluminum radiators all leak (eventually) and they could pretty much wager on them leaking in a year. they repair radiators, regular and aluminum but mine was leaking in a non-repairable spot (top inside corner edge) which was really hard to find since it was a very slow leak and was drying from the air and not leaving any drops on anything i only spotted it because there was a dry discolored spot with a slightly redish tint after i pulled the fans out and looked with a flashlight.
I initially considered getting another cold case since it was under warranty but the 1st one took about 3 months to get and they were still on backorder so I said screw it. Mishimoto didn't seem to be any better either.
Foggy
KS
That AFE radiator doesn't really list the exact specs... so IDK on core thickness...
I've had my Mishimoto in for almost 3 years now with no problems...
So I wonder if there's something whacky going on with your mounts or core support ?????
My 14 is almost the same specs as your 6.2... I didn't know cam motion did VVT cams
for our Gen IV's...
I did the Gwatney cam... I think your prob idles smoother with the wider lobe sep !!
When I had my SC on, my trans still ran warmer than I'd like it to even with the big
mishi radiator...
Once I took out the factory aux cooler and did the one below my bumper (with a fan)
it's so much better towing.. But I think my intercooler was shedding a lot of heat into
to air stream ( it's first of course)..
It's still there, but I took off the SC for repairs and decided to go with Cam and
have my heads just massaged a little bit
wcter
