AFM delete
ridewot
ct
Any recommendations for a good AFM delete unit ? Have a 2008 Tahoe 5.3 120,000 miles
Thank You
I have no information on AFM delete units, but others on this Forum will chime in. You can also delete the AFM through a tune, such as a Blackbear tune, while enjoying the performance improvements.
Thank You
You might get more help if you posted this in the NNBS/GMT900 section. This is the 2021+ section. Maybe a mod can help @07Burb @Fless @Miami-Dade @NathanJax
To get the ball rolling, what exactly are you referring to as an "AFM delete unit"? A plug-in module to disable AFM from engaging or an actual delete where you replace the AFM parts with the non-AFM counterparts?
ridewot
ridewot
ct
Just looking to disable the AFM mode
OklabyGodhoma
Normal....er, Norman, Oklahoma
Just got all the parts delivered yesterday from Texas Speed; almost $900.00 worth but they are all high quality including a new cam, lifters, trays, gaskets, every single bolt and stud required to do a first rate AFM-DOD mod. Looking at just over $2K for labor but the ‘07 has less than 140K miles so I think it’s worth it.
If you are thinking about it just have your VIN and call Texas Speed and they will walk you through the process and save you money. I was about to order online and decided to call and it saved me over $140. on parts alone.
Did they send you the little LM7 camshaft or the LM33 shaft?
OklabyGodhoma
Let us know how she runs afterwards, that grind is smaller than your original camshaft. The L33 is the same grind without AFM.
Correct, since I don’t tow and not looking for performance other than the best MPG I can get were my reasons for the choice. I know others are looking at how fast they can get off from the light or better acceleration from 70 mph. I on the other hand have to idle for extended periods because I use my vehicle as an emergency volunteer during severe weather or other disasters. And even with a smaller grind it’s still a 5.3 and has horses to spare when needed.
dizhai
