a few general questions about my truck.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
just as i thought. order now: http://www.amazon.com/ACDelco-TR7-Fuel-Sender-Cam/dp/B000C9SNLC
97blueyuk
97blueyuk
quick question before i put the tank back up. When taking it down, there were 2 fuel lines on the tank 1 left 1 right, nothing on the center. Is that the correct way or is there supposed to be a line there?
SunlitComet
OBS Jedi-Do Good
correct. but you know while you are at it if you think you will need to changes your leaf springs, take the mounting bolts at the spring bolt in back of left leaf pack, remove them and put them in the other direction. otherwise the tank will have to be moved again.
97blueyuk
97blueyuk
okay tank is back in place, new cap and rotor are on, need to get a diff hose clamp for the hose next to the filler hose. Then I will go for a drive....
ASG-MikeS
