99 Tahoe 2 Door Getting Rear Disc Conversion
Bunch of hooey
I put the larger Front Calipers on as well. These are from a 2500 series truck from the same gen as ours. I have a comparison picture of the two calipers. As you can see there is a slight difference in size and the pads are about the same size but maybe just a slight bit bigger. They are a bolt on as well with no mods. Also with the changes I have made to the calipers I now have to use a master cycling from a NBS truck. They have a larger bore for larger caliper on both the front and rear now. I will be installing that today as well. Here are a few shots below.
View attachment 209251 View attachment 209252
Excellent detail! How well did the conversion improve stopping and pedal feel?
jdaly
It looks like I might be doing the same with mine. @1LOTAHO how much of a drop did you do your Tahoe?
jdaly
I think my last reply didn't go through. @1LOTAHO I think I'm going to go with your same set up and a drop as well. ** much of a drop did you do on your truck and how does the ride feel? Are there any pros or cons to the suspension drop?
Moderator
People's Republic of Colorado
Unfortunately the OP hasn't been on here since Dec 2021.
CKendrick
