97 YUK Brake Nightmare...HELP????
97YUKLVR
PA
Ive replaced everything front to back including the ABS Module...calipers...master cyl...wheel cyls.....Still have super soft Pedal...basically goes almost to floor....Bled..and bled and bled again....still soft...what am I missing?????
gitrduun
Its your master cylinder, your primary seal is leaking
97YUKLVR
PA
Im literally on the 3rd NEW Master Cyl....have not changed the booster....with engine off I have pedal...as soon as its started the pedal goes away
geo3xk
mansfield, oh
Only thing I can think is there's either air still in the line or some of your rubber flex lines are swelling.
97YUKLVR
PA
replaced the flex lines too....cant see how there is still air in there....seriously bled the damn things half dozen times...have 1500 bucks tied up already....the ABS module was over 800....ready to break down and take to the dealer ....now thats frustrated!!!!
geo3xk
mansfield, oh
I understand your frustration. I couldn't get my abs box to bleed out so I had a soft pedal from that. I ended up bypassing it now my pedal is perfect. Maybe someone on here can chime in on a way to actuate or bleed out the abs?
retorq
Kingman AZ
You did the ABS module and the proportioning valve at the same time?? I had some issue, I ended up swapping to 3/4 ton master, calipers and pulling the ABS fuse. It's pretty good now, when I get around to my hydroboost I'll bypass the ABS completely ...
gpracer1
Phoenix
I'm not sure why people seem to think that the abs has anything to do with pedal height or firmness? It does not. The pedal will be either soft or low pedal height if there is air in the system, the shoes are out of adjustment, the shoes are on wrong, ot the master is bad.
geo3xk
mansfield, oh
That's what im saying if the abs box has air trapped in the system it will leave no pedal height. I had to bypass mine in order to firm up my pedal because I couldn't get the air out of it. It was more of a question, how do you bleed it? Can you actuate it while not moving?
gpracer1
Phoenix
If the abs unit is actually working ok, you could pound the brakes a few times on a dirt road to get the abs to cycle, then bleed the brakes like normal.
Or drive over 3mph to let abs initialize then jack up all 4 (without turning engine off) and spin one or two tires and hit brakes to cycle each....then bleed.
Donnie Yukonie
Yates Caretaker
upgrade to Stainless steel lines rubber lines flex and expand too much even when new steel braided does not
j_jerry79
