Ive replaced everything front to back including the ABS Module...calipers...master cyl...wheel cyls.....Still have super soft Pedal...basically goes almost to floor....Bled..and bled and bled again....still soft...what am I missing?????
I'm not sure why people seem to think that the abs has anything to do with pedal height or firmness? It does not. The pedal will be either soft or low pedal height if there is air in the system, the shoes are out of adjustment, the shoes are on wrong, ot the master is bad.
That's what im saying if the abs box has air trapped in the system it will leave no pedal height. I had to bypass mine in order to firm up my pedal because I couldn't get the air out of it. It was more of a question, how do you bleed it? Can you actuate it while not moving?
