4L60 Types and Differences
Coolman1987us
Maine
I'm looking to rebuild a 4l60 for my 08 tahoe and i was wondering what the differences are between all the different years. I have two that were behind a 97 and a 98 both 305's, i know the bellhousing is different. I'm just curious how different they are and if i could rebuild and older one with new parts, specifically 2008.
NickTransmissions
Sin City
The transmission bench
The front and rear gear set will interchange, as will the reverse input drum, output shaft, low reverse piston and return spring...In the forward drum, the clutch packs are the same; the input sprag assembly is exactly the same between the 1998 and 2008 units; the 1997 and earlier units used a detached front sun gear-sprag set up but they will prospectively install into any year 4L60E 1998 and up as a service pack.
Your bell housing, pump, valve body, input drum itself (specifically the input shaft), separator plate, wiring harness are all different and WILL NOT interchange between 1997/1998 and 2008.
What's wrong (if anything) with the 2008 4L60E in the Tahoe now?
strutaeng
Dallas, Texas
Here's a source that has most differences covered:
That's overall units compatability. Not sure about mixing and matching internals...
NickTransmissions
Sin City
For those reading through the above-posted LS1 Tech thread, the main contributors are Vorteciroc and MaroonMonsterLS1, both former General Motors powertrain engineers who worked extensively on the 4L60E and 4L80E so know those transmissions backwards and forwards. They are great sources of information for those transmissions.
Coolman1987us
Coolman1987us
Maine
Thanks for the information. The transmission in the Tahoe now is still behaving good I just want to swap in a working transmission when this one goes. I'd rather not have to leave the truck on the lift while I rebuild it's trans.
petethepug
Michael
SoCal
@NickTransmissions … Just thanks for your contributions and peace / piece of mind in the forum. Ok, back to your morning coffee with the peeps in LV
