2023 22's onto my 2013
the blur
Cyber Space
2023 Escalade 22's onto my 2013 LTZ. Will they fit ?? MY 2013 LTZ has the factory 20's. But I have a line on the 2023 Escalade takes offs.
Is the bolt pattern and offset the same ?
Trey Hardy
Yes it’s the same it’ll bolt right up no issues
solli5pack
I got late model GM 22's on my 10 Burb & 08 Yukon. Bolts right up but rubs the fender liners slightly when turning in reverse.
T
the blur
Cyber Space
So the 1" extra in diameter doesn't matter??
How about the TPMS ? Do they match up to the older vehicles ?
petethepug
Michael
SoCal
If they have rubber on em, see if u can test drive em. If your LTZ has z55 autoride it’ll make that rim & tire combination behave like no other.
adventurenali92
Big Bear Lake, ca
You will need to swap the sensors over from your current tire setup. Bit other than that they should fit with no issues. I have 2021 Yukon take off 20s on my 2006 and they bolted right up.
91RS
GA
The wheels will work fine but the tires are too tall and will rub and the sensors will not work.
T
the blur
Cyber Space
ok, we have 1 vote for tires being too tall, which they are 1" larger in diameter. and a bunch of votes that they will work fine.....
solli5pack
GM 22" wheels on both my trucks. Not sure what years they're from but they synced right up with the TPMS. Both rub the plastic fender wells when turning in reverse slightly. The rubbing can be eliminated with a lift kit or use some persuasion with the fender wells to pull them out a bit or just ignore the rubbing. The ride of both trucks improved with the bigger wheels.
Buford bubba
