2017 Escalade ESV
Tahoe14
Central Fl
Looks like a good deal according to the KBB and other car value sites used to determine the value. It would be better if it was a true GM certified pre-owned instead of a DGDG certified. You may want to ask if they can GM certify it which is a better warranty. My only concern would be the severity of the accident which Carfax should show. You may want to run a Carfax or ask the Dealer to provide one.
Thrust
ICT
I would ask and check the magnarides and also check that the TSB has been done on the transmission for the fluid swap.
Rdr854
Northern VA
Also need to have the body work checked. We’re OEM or after market parts used? Did the body shop take short cuts that the average end user would not be aware of?
GTNator
Senior Member
It’s 2WD, not 4WD, correct? Prices are lower on 2WDs.
C
captain
2WD. Still looking around and finding that to goto a 2018+ its not going to be much more expensive. ESV's seem to be very competitively priced when compared to the regular sized possibly cheaper on the used market.
albac
