2013 Yukon..Strange screaming noise/smoke from passenger side of engine bay
mtnboydl
Hey all-
I've been a lurker for a while but finally have hit something that stumps me entirely. My wife drives a 2013 Yukon that has been great since we bought it used about 4 years ago. It now has just over 100k miles and has only needed basic maintenance (and a new accelerator pedal for the sensor).
This morning we started the vehicle and it started to have an intermittent loud screaming type noise. Not quite like a belt squeal, somewhat more intense. I have uploaded a video for your review.
https://photos.app.goo.gl/kZ5yUybk6Npzt8xi7
It can be provoked by accelerating slightly while in park.
When the sound happens, some smoke accumulates in the engine bay as well (burnt rubber smell, so maybe it is a belt??)
We recently had a P0455 code pop up, but it seems unrelated to this problem and more likely that I need to replace the gas cap.
Any advice you guys can offer would be huge in helping me knock this out today!
M
mtnboydl
I've got a friend who suspected the AC compressor relief valve but I'm still going down that rabbit hole at the moment.
wjburken
Eastern Iowa
Hey all-
Welcome to the forum.
You most likely have a bearing going bad on one of your pulleys. I’d look at the idler pulley for your serpentine belt first, but it could be your alternator, water pump, or A/C. Need to see if you can get a mechanics stethoscope and see if you can pin point the source. They are rather cheap at Harbor Freight or Autozone.
take the ac belt off, you can leave it just dangling, if the problem is gone then you can still drive it and fix the compressor issue later, don't need ac right now anyway.
M
mtnboydl
Thanks guys. I am trying to get it to reproduce the sound but nothing is happening. I suspect a bearing issue would cause the smoke to happen? You can see it at the tail end of the video.
May also correlate with the AC compressor clutch engaging (although it won't do it now, of course...)
wjburken
Eastern Iowa
I think the 2013’s use a stretch to fit belt on the AC. If you take it off, you should replace with a new one so I’d cut it off and plan on replacing it.
there is nothing else down there but the ac pump and nothing else that would be intermittent, when the compressors go they do some weird stuff, to be safe I would just take the belt off before it freezes up on the highway or blows the compressor out and you end up having to replace the whole ac system. I'm 99% sure the compressor is freezing up and then the belt is still spinning causing the smoke.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
yes it's a stretch belt, you can get it off with a screw driver and turning the balance with a socket wrench, or just cut it :)
I never heard of this stretch belt shit. Is that for real? LOL. WOW. :confused:o_O Learn't sumptin today.
89Suburban
SE PA
Yeah, I ran into that when I had the 2009 Suburban. Went to buy new belts and kept coming across “special tool required”.
Holy crap. I would never have thought a stretchable belt could be reliable. Or even be made. Crazy. Thanks for the warning lol. Stick with my '07 for a while.
I think they went that route for a couple reasons 1. to save money & time one less part to put on. 2. it eliminates the tensior pulley making that god awful squeaking noise when they start to fail.
wjburken
Eastern Iowa
LOL!
I think a lot of the European cars have been using them for a while now.
I’m sure it is a cost savings measure and a very very very slight bump in fuel economy since they don’t have to pay for the idler assembly and there is a barely detectable reduction of rotating mass and friction from one less idler pulley.
Hey all-
As others have said, replace the belt but you may need a new clutch for the compressor too. You do not HAVE to replace the whole compressor on these as they sell a replacement clutch nowadays.
Seamus
Palm Beach
As several have said, it really seems to be the AC compressor. The location of the smoke comes from that exact spot too. I have a 2013 and it is a stretch belt. I used a brand new razor and it sliced right off. It is behind the serp belt. Gates makes the tool for about 7 dollars to install and it works well. I'd get a light and eyeballs on the compressor as someone helps reproduce it. Compressor is not too expensive, I'd replace the entire unit, if thats what you determine.
steven ross
Hey all-
Does she brush the curbs a lot when parking? My wife had a similar sound, and does that a lot.
Hodmjstone
