2013 Chevy Tahoe Dashboard
KntryMama
2013 Chevy Tahoe LTZ
Last 8 of VIN: DR153082
I have to replace the dashboard (both pieces).
I know that I can interchange the Tahoe, Yukon and O believe Avalanche dashes. Is it the same year I need to look for?
Is there any sites that are recommended?
And does anyone know the part numbers?
Thanks for any help
Thanks for any help
there is only 2 dash, one with a center speaker and one without. (as far as I know, unless it's a escalade of course)
the front piece can be replaced with a dorman (see link below), several of us have purchased it, it matches the original very well
alpha_omega
Michigan
^X2^
@t_bergman 's writeup is the best!
x3 and 4. He’s laid it all out. The only thing you may have to do (which I should probably do a write-up for, is painting the dash to match). I’ve done two different dashes on Yukons and one required painting first. I paid $250 for an OEM dash, so the color didn’t matter at that point.
kbuskill
NE. FL.
Slightly off topic, but since you mentioned painting the dash...
I have an '08 Burb LTZ with the light Titanium/Dark Titanium interior.
I ordered a touch up pen from Colorite in dark Titanium and it is too light. I thought they sent me the wrong one but they sent out another and same issue.
The numbers on there site match my RPO sticker in the glove box
Dark Titanium Gray (Interior) WA313N​
Do you have any ideas?
My wife had one of those liquid air freshener things in the vent and it leaked out onto the dash and removed the dye leaving the spots black.
alpha_omega
Michigan
You’re lucky that’s all the damage it did. I’ve seen those air fresheners mess up some dash and trim pieces.
Eastwood is the company I went with. I can pull up my order and get you the info if you’d like. There was a primer used for the plastic and then only one top coat was needed. Bonded great. They have paint pens as well, but even the ACDelco/GM Genuine pens color matched don’t ever seem to match quite right.
kbuskill
NE. FL.
No need to trouble yourself, I will check with Eastwood and see about getting a pen from them. Thanks for the info.
I was just curious if you had ever had any issues with the color not matching.
I always have used SEM paint to for interior panels, they all come black and any color you see besides black is painted on
alpha_omega
Michigan
Not with interior. But my other Yukon was Pewter (exterior) and Light Grey (interior). My Denali is Ebony (interior), so there wasn’t any issue. The only problems I’ve seen are guys not cleaning, priming, and cleaning again before paint.
alpha_omega
Michigan
I normally like their stuff, but their paint pens didn’t match my light grey interior or the green exterior on my typhoon.
Tuglaw
Does anyone have any suggestions for a shop that would do the top dashboard replacement, both pieces, for my 2013 Tahoe in the Pittsburgh, PA region? Thank you.
mikez71
Sorry I don't know any shops in your area. BUT, I suggest you may try it yourself. Tom has an excellent writeup here...
After removing a few trim pieces, it's not too much work if you take it slow.
You don't need many tools (7mm, 10mm + extension, T6 torx, plastic prybars and screwdrivers).
I've been driving for a week with my vents, trim, airbag, glovebox and radio removed, just to make sure I have ample time to finish it once I work on it again(today!).
Here is the first day I started removing parts. Extended adjustable airvents patentnot pending.
Marky Dissod
I've always wanted to have extendable airvents that would let me place one end up my sleeve or up or down my shirt.
Keeping the entire cabin cool costs more energy than keeping ME or US cool ...
mikez71
It really was an improvement for airflow directed towards your body.
Only thing, I had to swivel the left towel vent to the right so the shifter stalk can clear it..
Now if that center vent just extended straight out, with swivel ends...
It keeps you cooler forsure..
Coveman
I got one of these for the burb before it started cracking. Fit perfect and still looks new after 6 years
Auto Dynasty Front ABS Molded Dash Board Cover Cap Overlay Compatible with Chevy Tahoe Avalanche Suburban Silverado GMC Yukon XL Sierra 07-14, Gray https://a.co/d/6w6GyM5
Cheney
Thanks for any help
I replaced the digital cluster
1948Buickroadie
