2011 ppv 5.3
80Z1R
Just curious what I should ask for the motor out of my 2011 ppv. I replaced it due to a couple cylinders low on compression and a failed oil pump o ring. was still running well but kicking sel on. has 130k on it. I thought about rebuilding it for a swap into my 63 catalina. but just do not have the time or space to jump in to that at this time. Motor is complete minus fuel rail. Any help is appreciated.
RichardCranium
Mebane, North Carolina
The 'sale' would be that it does run (not broken or "unknown"), it'd be perfect for someone looking to rebuild as stock or to use in the hotrod world, but knowing it needs to be completely gone through. If it were me I'd ask $1000, but would take $750.
Ilikemtb999
Denver
I see running gen 4’s for under a Grand here. A builder to me wouldn’t be worth more than $400
wjburken
Eastern Iowa
I would see what folks are getting for long block cores and you might be able to sell it for around that which I think would be between $400 & $600 depending on where you are.
