2008 Yukon Denali, 135k miles, part 2!!
Yep, time to break out the big boy tools. I did upper ball joints on my burb this last weekend and has to break out the BFH a couple of times to get that bolt out. They stubborn but they just need a little persuasion :D
T
tgui
Air hammer, big ******* hammers, kroil for days etc. Nope.
I need this torched out and I don't have a torch.
I suppose I should put it back together with the arms and have someone else do it.
**** salt! ;-)
randeez
south florida
memory maybe a little fuzzy, but i dont think those bolts unthread out. the bushing and the shell has a rectangular shape that the bolt goes thru. you just need to hammer the bolt out.
i would do some research before beating the shit out of it with a hammer but i thought thats how the older trucks were anyway
That would suck. He did try to hammer it out with no luck.
T
tgui
Sleeping on it I'm not in a time crunch and maybe could use this as an excuse to buy more tools rather than pay labor hours.
Is this a dumb idea to get? ;) (or something like it) I have a fire extinguisher and hose in the garage. lol
trailblazer
I live in the great white north and my go-to friends are my Milwaukee brushless M18 1/2 impact (1100ft/lb?), Port-A-Torch set, and the Mayhew Shake N Break air hammer socket adapter set.
I recently started to use the Shake N Break 1/2 and 3/8 and they are PRICELESS. While it’s hammering the bolt you turn it with a 3/4” wrench. It’s a total bolt saver. Some bolts still need to be heated cherry red but when used with the Shake tool they don’t snap. Pair are $30.
https://www.toolsource.com/air-chis...lt-breaker-air-hammer-accessory-p-148800.html
T
tgui
Surely the passenger side will go better!
1st bolt ripped off. The shop is a block from my house.
kbuskill
NE. FL.
Good to know. Thanks for the ideas!
You probably want to get a couple of them as you will only be cutting with the very tip of that blade due to clearance issues... it's not like you can get full use of the blade in this situation... but you can keep the blades for later use.
brice715
