2008 Suburban NORCAL 2/3 drop Ebrake line issue
scottierass
Installed the kit. Love it. I'm having a problem with the drivers side rear e brake line rubbing on my new Arnott air shocks. I've routed the line both in front of and in back of the shock and it rubs the air bag both sides. What have you done to correct this?
ride handsome
Mine is doing this as well. I have some Sway bar relocation brackets on order that are supposed to fix this.
S
scottierass
How will re-locating the sway bar help? It doesn't change the routing of the brake cable or shock location....... does it?
S
scottierass
I also have NORCAL sway bars and rear end links.
ride handsome
I have no idea. My buddy recommended it. He is a mechanic and has done a bunch of tahoes. Ill let you know if it helps or not.
08grey
I tie strap mine to the bottom bolt on the relocated bracket. I think I took them out of the metal holder to get a inch more slack.
Sent from my SM-G950U using Tapatalk
ride handsome
I asked my buddy and he says the relocation kit comes with new shuck brackets that fix the problem. They should be in early next week so I'll post some pics of the install.
Heres where mine rubs:
S
scottierass
Any update on this?
Pelon222
same here Tony, can you maybe explain it here and if possibly add some pictures
NORCAL SS
SUV SUSPENSION GURU
Remove bracket
Route line toward extender
Ziptie line to extender
Done
Durobans
