2007 Tahoe LT - No power to radio, no sound for signals, tones etc
JKB65
HI.
Got into our 07 Tahoe today and found the radio has no power. There are no turn signal sounds ( signals work but just have no sound ) and no audiable chimes from key, back up sensor, open hood, etc.
Fuses seem to be OK.
I tried the exit, lock, wait, unlock and start sequence as someone had suggested on another post but that has not worked.
Anyone have suggestions as to what else I can checK? I don't really mind replacing the radio itself IF that's the actual problem but don't want to spend that kind of money if it doesn't fix the issue.
Any help would be appreaciated
Thanks
NRKR97
I am having the same problem as well and it seems like I can’t find any answers. Please Post any help.
All chimes and other sounds go through your radio. So you've checked the radio fuse under the hood? Is there more then 1 fuse tho? Might be 2 fuses.
BlacktopBandit76
