Finally! I found more than a couple of people that have the same issue
Not a good thing really but good to here some things that have been attempted to fix the situation.
For mine 2008 Yukon Denali, 129K miles on it. Only came about on mine after we purchased our travel trailer and went on our first trip. Trailer is around 5500 pounds fully loaded and is 24 foot long, shouldn't have any issues towing it.
As with others after coming to a stop from a about an hour on the highway, it just died, crank and crank and nothing. no check engine lights, no codes etc.
The only thing that I found to get it to start other than waiting is peg the gas pedal on the floor like and old carb car to get it to fire again and after that it would run fine. Or when coming close to a stop, put trans in nuetral and feather the gas so RPMS stayed up.
Engine temp was hovering around 215 ish and trans was about 195 maybe 200 when it first happened.
Everything is near stock on my truck minus the K and N intake and PCM4less tune that I am running. IT runs absolutely fine all the rest of the time.
I am not one to throw parts at any sitaution I like to find the definite answer, but this is just baffling so the list of stuff I am going to do:
- Change the thermostat and the relative fan on times in the tune, going to try a 160 thermostat
- Put in Tru Cool 40K cooler for the trans and ditch the factory cooler.
- I bought silicone wrapped fir proof sleeve for the fuel line, do you guys typically disconnect the fuel line at the rail and with a big enough sleeve just slide it over and down or is there an easier way to do this?
- I may change the oil, but not sure if this will aid in much.
Has anyone found the defnitive answer to this issue that I missed?
I found a conversation on another page where it was recommended to change the THECU in the trans due to a sticking solenoid or control. If I have to dig into the trans I am going to sell this thing lol
Thanks
