2005 Z71 driver's side mirror
OR VietVet
Multnomah Falls
Military
Willamette Valley
When I am driving at higher speeds the glass part of my driver's side outside mirror shakes. I have checked the difference from side to side and the glass is definitely looser. I saw how I can pry the painted cap off the mirror but is there also a way deeper in there to check and hopefully fix the glass looseness?
S33k3r
Dallas, Texas
This should be similar if not the same to what you have:
Here's another one:
I just Googled "tahoe mirror glass".
That will get you into the mirror at least, so you can see what is going on.
Good luck!
OR VietVet
OR VietVet
Multnomah Falls
Military
Willamette Valley
I see where I can just buy the assembly and swap the painted cap or just do the mirror. What I am worried about is that there may be a broken clip capture tab that stays in the housing when you pry out the mirror assembly and then I have a mirror that I need to return and then buy the assembly. It does not look good for removing the old mirror and then having a chance to reinstall if the mirror part is still good.
Gonna do some thinking on this and may just get both from Amazon so the return is easier.
S33k3r
Dallas, Texas
I don't know how much that assembly would cost, but you might just want to watch FB Market place and/or Craigslist (or similar) for a part out. Get a whole assembly from that.
Big Mama
Virginia
Not sure if 06 and 07 are the same type of mechanism but mine was 2 ball and sockets holding the mirror in. It was hard to get myself to push hard enough to pop it back in. I ended up getting a new mirror and changing the cap, as you mentioned.
OR VietVet
OR VietVet
Multnomah Falls
Military
Willamette Valley
@S33k3r, I messaged him. Thanks. I may be interested in the radio/cd player and the dash heater/a/c controller. That isn't a bad price for the whole thing though.
BWASTEEZE
