2003 Yukon problem
Nyjetfan21
I started my car up about three days ago and realized my service airbag light is on. Is it dangerous to drive the car like that and how can I diagnose to find out which one is bad or can it be something minor and easy to fix
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
First, it is a Tahoe or Yukon or Escalade on a truck platform and not a car. I am just giving you shit, don't take it the wrong way.
Second: Need to pull code(s). Post them here and report back.
Third: I don't think it is any more dangerous than driving an old vehicle without air bags.
We recommend that you put all your rig(s) info in your signature so we all don’t have to guess at year, make, model, engine size, trans, rear axle locker…….etc. While you may have posted pertinent info in your first post, you may forget to do it again and the info is needed by us anyway. Makes it way easier on all members that attempt to help, to have that info right up front. It is also recommended that you take a pic of your RPO codes, on the inside cover of the glove box, and post that image in your signature. All this info will greatly help those that will try to help with a problem.
If there is any other info, like upgrades, mods or recent mechanical/maintenance work done, that would be helpful in any post as well. Too many times a question is asked by the poster and after about 10 responses we find out that the poster has done recent work to attempt to fix the problem or work that was done that SEEMS not related to the problem.
HiHoeSilver
Away!
Chicago
99% of the time its one of the front impact sensors. You can:
1. Use a high level scan tool to see which one.
2. Buy a sensor ( best in the classifieds here or on eBay) and change one out. If the light doesn't go away, swap the one you removed with the other existing one.
The airbag light does not require codes to be cleared, the light will go away on its own if you've fixed it.
Big Mama
Virginia
If your state requires annual inspections like VA get it fixed or you get the dreaded red sticker.
N
Nyjetfan21
Can you actually pull a code for a airbsg light even if your engine light isnt on and will truck pass inspectiin with the airbag light on. Also the truck is A GMC YUKON 5.3 L
Fless
Moderator
People's Republic of Colorado
Can you actually pull a code for a airbsg light even if your engine light isnt on ...
Yes. The CEL is for the drivetrain only, primarily emissions issues. The airbag light is for the airbag system and you would need a code reader that reads airbag codes. Separate systems. Most inexpensive readers will read engine codes only.
Drewphil
