Kent Kimberlin
- Joined
- Jun 5, 2019
- Posts
- 7
- Reaction score
- 9
Periodically my check engine and brake light for parking brake will come on for no reason. They will stay on for a while and then go off. Help?
Weird. Did you scan it while the cel was on? Do you have a scanner that does abs/brake codes?Yup and no code! I am thinking short. Just wanted to see if anyone else was experiencing this. I have 2002 BTW I should have said that
your scanner must be able to read abs codes even if the light is illuminated, if there is no stored code for abs then it may be likely the abs module is/has developed a short (very common) the solder inside gets loose from years of rattling down the road, like if you hit a bump on the road and the light comes on and then when you cycle the engine the light is out again. if the scanner can read abs codes and you scan when the light is on it will say something to the affect of "abs circuit failure" if it is the module. they can be repaired by reflowing the solder points inside.No I did not good point. I'll try the scan again (when the lights are on!)
Check Engine lights are all the rage on many of the trucks on here. With so many sensors it's a common problem even when the truck runs perfectly fine. I have my ABS and BRAKE light come on together than go off together. I have a noise coming from where the rear heat and a/c are when I turn stuff on like blinkers. I had a rear wiper issue so I took the wiper off. Its a life long rust free Yukon from Texas that only has 165k on it. I removed all the seats and pulled up all the carpet and plastic to see if it might be a flood truck but it is very clean with no sign of water damage. The truck runs great and is fun to work on because of how clean everything is just a few electrical gremlins to figure out.Periodically my check engine and brake light for parking brake will come on for no reason. They will stay on for a while and then go off. Help?
