1996 Tahoe Question?
Texas
Didn't know where this question would go, and couldn't find anything. If I buy a replacement key for my truck, does it have to be programmed or are they non-chip keys?
McFizzl
Broke as a Joke.
Fayetteville, AR
even my 97 doesnt have a chip. you would see the chip if you had one. it would be embedded in the metal part with plastic.
Donnie Yukonie
Yates Caretaker
I believe my 98 is chipped…. i remember getting a key cut one time at a local hardware store and it would start my truck but it would cut off after 5 seconds every time
saif najd
Is it true that you should have the real or ginune engine key? and to use it from time yo time or the engine well not start?
I faced it with a friend his 99 Yukon didn't start until he used the orginal key after that start he can use the copy again!?
inthechateau
Maryland
My 99 does not have a chip visable. Going to try a dup key to see if it works. Like to find a couple of new remote fobs that work though.
96twodoorTahoe
Texas
Do you have the stock alarm system, or is it aftermarket. I usually use Ebay; you can find brand new remotes that usually come with programming instructions for pretty cheap.
Drewphil
