TBC-IGN1 fuse necessary?
mikez71
I pulled the TBC-IGN1 fuse. (truck body control, powers BCM when key is in run & start)
It kills the key-in-run chime that goes off if you don't start the vehicle right away!!
(Key-in-ignition is seperate circuit also easily disconnected to 'fix' that chime)
(Seatbelt chime can be unplugged or programmed off with Tech2 in SRS settings)
TBC-IGN0 powers BCM when key is in accessory & run & start.
TBC-ACCY powers BCM when key is in accessory & run.
Engine starts ok. Do I need this fuse for anything?
Will report back if I find something not working..
Towmaster
