14 bolt swap with ics
kelly1
Central Kansas
Just a teaser for now guys and gals. I got it freshened up and painted. Brake parts are cleaned and waiting for install. I'm gonna use my tahoe e-brake cables so I'm waiting to install the brakes till I do the swap.
Swap should happen this coming Sunday.
K
kelly1
Central Kansas
I know right. I often wonder why I spend so much time cleaning and painting things that will just get dirty and form surface from road rash the second they are installed on a daily driver. It must be my gearhead OCD. HA!
K
kelly1
Central Kansas
Out with the old, in with the new. It's not as purty as I wanted since I decided to weld the sway bar mounts to it but it is a daily driver and I live on dirt/gravel roads....
Nothing special about it. just a 60k miles original rear. I put new spider gears in it and seals. The bearings all looked great and I was budgeting this one. It's much quieter than my 10 bolt that was about to pop and should last a long time.
AtomicHoe094
Atomichoe094
cleveland, OH
Nice! you have a burban or tahoe? The sway bar is a good upgrade for tahoes since they didnt come with them from the factory.
K
kelly1
Central Kansas
I've got a 4 door tahoe so I had the factory sway bar already and decided to swap the mounts while I had everything apart.
Including what I paid for the rearend and the spider gears I have $400 in it, plus u-bolts and other items on top of that.
AtomicHoe094
Atomichoe094
cleveland, OH
thats not too bad at all! i put around 8 to 900 in rebuilding my 10 bolt from the ground up, did the work myself which saved around 700 bucks labor
K
kelly1
Central Kansas
I hear ya. I thought the same thing and instead of rebuilding my 10 bolt I went with the 14 bolt since I found one so cheap. I don't do any off-roading but do haul a car trailer several times and figured the 14 bolt should work fine for me.
PLUS I'm a glutton for punishment and figured a swap would be a good way to remind me of how not-young I am getting. lol
AtomicHoe094
Atomichoe094
cleveland, OH
haha. Sounds like it worked out well for you then.
Did the 14bolt have bigger rear drums or the same size? any difference in stopping?
K
kelly1
Central Kansas
I think I've read where some people have 10" rear brakes. My 10 bolt had factory 11" brakes and that's what the 14 bolt has, albeit the drums weigh about 100x times more than my 10 bolt brakes did. lol
Seems to stop the same though. Everything feels great. I can tell the extra weight is back there on take-offs but it's not too bad at all. Worth all the hassle!!
Zach_Granger
