1-2 shift problem?
Eagle_XL
Chicago
This morning I started the truck and let it warm up for a couple minutes in the driveway. I backed out and drove away, but when it came time to shift to 2nd, the trans did something weird.
The truck felt like it lost all acceleration, although the engine held its RPM... then after about 1.5-2 seconds of no power to the wheels it shifted gently into 2nd and drove fine the rest of the morning.
What's up with that????
E
Eagle_XL
Chicago
No way... the trans can't be bad. It drives perfectly otherwise, it was just this one glitch so far.
I thought I'd read somewhere about 1-2 shift problems on the T&Y trucks... hrmmm... maybe I'll try and find out more on that. I definitely see lots of guys installing corvette servos in their 4l60e's....
---------- Post added at 01:36 PM ---------- Previous post was at 01:35 PM ----------
Ah, and I'll check the fluid as soon as I get it home tonight! :D
BOSS
The People's A D M I N
Dallas
FWIW I would replace the fluid and monitor. You're right on that 100K clip so I would personally go with Mobile1 full synthetic and monitor.
Not to mention your tranny was cold anyway.
E
Eagle_XL
Chicago
Yes, the truck was relatively cold still. It had just been idling maybe 2 minutes tops.
Trans fluid change. Cool. Did GM ever put drain plugs in the trans pan on these? Sure wish they would like they do on the newer cars now...
blueflamed03
Oklahoma
sluggish shifts 1-2, really bad when colder temps. I could be sitting sometimes at a stop light, go to hit accelerator and it feels like it's taking off in OD not first. let off accelerator, and then it engauge in low gear and go thru gears fine.
26AT4
