07 Tahoe, which leveling kit to get?
ispperformance
I want to purchase a leveling kit for my 07 Tahoe, and was originally going to go with a ReadyLift 1.5" kit, but don't know? I kept searching for other kits, companies, ebay etc.... ReadyLift is a little pricey at $229, eBay has billet kits just like ReadyLift for $80? Do I go 1.5" or 2"? I need to order something soon, but I need some input.
InTruckDesign
SW CT,
Go to ebay and search CCM Offroad, I know Dan has a store on there. I would recommend the 2.5" front 1" rear kit. His kits are very stout and probably one of the most used out there.
I
ispperformance
Unable to find that kit on ebay.... How is that kit with alignment? Can you get it to spec without any additional parts? Also, I know you guys will cringe when I say this, but I have a Plow on my Tahoe, what do you guys think of a lift kit with the plow? (its a Boss sport duty, light weight).....
2 E L O
Omaha, NE
Can't say much about plows....but I have the 2.5"/1" CCM kit, as well. The alignment needed just a small change and CV angles are acceptable. There's no friggin way I'd pay $229 for a 1.5" kit. I don't think you'd be at all satisfied with only a 1.5" kit--the cost and amount of work is just not worth it. IMO go 2.5" front/1" rear or leave it stock.
CCM Offroad 2.5"/1": $129
http://www.ccmoffroad.com/shop/index.php?l=product_detail&p=38
seankami
texas
2ELO- I have a 2WD also, whats the optimal size of tire that i could get with a 20" inch rim on that leveling kit?
Has anyone hear done a 6" suspension lift on these tahoes (2WD)?
thanks
2 E L O
Omaha, NE
thanks
I'm not sure where you got your information, but my Tahoe is 4WD.
If you do the leveling kit you'll be able to fit a 33" tire without major modification to your wheel well and/or plastic liners.
seankami
texas
2ELO- Sorry about that, I must of confused myself.
Does anyone have a 2WD with this kit an 33's?
Thanks everyone
I
ispperformance
Ok, the CCM ket seems like it isthe best bang for the buck, but what do you guys think of the welded steel vs. billet aluminum?
2 E L O
Omaha, NE
I assume that you're referring to the front spacers....??? The CCM welded spacer is extremely heavy duty....IIRC, CCM fabricated the spacer using significantly thicker sheetmetal (1/4" steel) than the flange on the OEM strut mount. As long as you go with a quality company like CCM, the welded spacer is MORE than adequate.
JasonW4141
