07’ 2500 6.0 differential and transfer case oil
Dasanii19
2007 Yukon XL 2500 6.0
What oil would you suggest for the rear/front differential and transfer case?
The same stuff your owner's manual calls for. I'm a big fan of OE fluids but had trouble getting hold of 80W90 from GM ACDelco so I went with Lucas Products. Don't remember what fluids the 2007 2500s take, they have a different transfer case then the later ones (MP3024) if memory serves.
intheburbs
SE MI
Transfer case just uses ATF - Dex6.
GM recommends synthetic 75W90 for both front and rear axles.
From my '08 owners manual...
Transfer Case
(Four-Wheel
Drive)
DEXRON®-VI Automatic
Transmission Fluid.
Front Axle
(2500 Series
Vehicles with
Four-Wheel
Drive)
SAE 75W-90 Synthetic
Axle Lubricant
(GM Part No. U.S. 89021677,
in Canada 89021678) meeting
GM Specification 9986115.
Rear Axle
Axle Lubricant
Transfer Case
(Four-Wheel
Drive)
Transmission Fluid.
Front Axle
(2500 Series
Vehicles with
Four-Wheel
Drive)
Axle Lubricant
Rear Axle
Axle Lubricant
I know those '07s use the 4L80, did they use another TC or get the new MP3024?
Derick
Indy Suburbs
I used valvoline 75w90 my burb. Worked fine. I need to do the front diff again... It looked awful when I changed it for the first time over the summer.
intheburbs
SE MI
You're right James. I always forget the 2007 "anomaly."
From the 2007 owners manual
Front Axle
(2500 Series
Vehicles with
Four-Wheel
Drive)
SAE 75W-90 Synthetic Axle
Lubricant (GM Part
No. U.S. 12378261, in
Canada 10953455) meeting
Rear Axle
Lubricant (GM Part
Automatic
Transfer Case
(Four-Wheel
Drive)
AUTO-TRAK II Fluid
(GM Part No. U.S. 12378508, in
Canada 10953626).
techno4x4
Front Axle
(2500 Series
Vehicles with
Four-Wheel
Drive)
Lubricant (GM Part
Rear Axle
Lubricant (GM Part
Automatic
Transfer Case
(Four-Wheel
Drive)
AUTO-TRAK II Fluid
Canada 10953626).
Do you happen to know the quantities?
j_jerry79
