04 burb stalls while stopping
Shatcher0428
Hey guys I have an 04 suburban and am completely puzzled. Occasionally during the week whenever I come to a complete stop the idle drops and it dies. It will immediately start back up but if I do not hit the gas will die again. It will even do it in neutral. Now in park it will remain running. This does it randomly and when I am driving 80% of time it runs great zero stalling. Engine has been rebuilt, new crank sensor and cam sensor, recently changed the coolant temp sensor due to failure and replaced pigtail at same time. After installation of new temp sensor is when I really started to noticed the stalling issue. Only engine code is Evap code. Any help would be great! Thanks!
Moderator
People's Republic of Colorado
Welcome to TYF.
A vacuum leak could cause a stall at low idle, also has the throttle body been cleaned lately? Is the IAC on the throttle body working correctly?
RED TAHOE LS
Rossville, Georgia USA
When was the fuel filter changed ?
Shatcher0428
Shatcher0428
I replaced throttle position sensor about 2 years ago, along with fuel pump, filter and regulator. Also has new mass air sensor. It is a flex fuel engine if that makes a difference. I didn’t think the 04 burn flex had an iac?
Shatcher0428
Shatcher0428
Do you know anything about the throttle control actuator? Could it be the culprit? I am thinking about replacing throttle body and getting new tca, the only code I am getting is a p0455
PNWYukon
Olympia, WA
P0455: Cracks, holes, or splits in EVAP hoses are typically the issue. Could be other things though. The EVAP issue should not cause your dying problems.
It's a 2004, then by all means change out the old parts, but without narrowing it down with some live data or a higher level scan tool, it will be a crap shoot.
just because the fuel pump is only 2 years old doesn't rule it out.....it's one of the 1st things you want to check before just throwing money at it.
Shatcher0428
Shatcher0428
Thanks everyone gives me some ideas to look at, on the fuel pump wouldn’t it do it more than randomly stalling? It cranks right back up immediately whenever it does.
Moderator
Maybe, maybe not. Only way to rule it out is to document the pressure at the time of the stall. Easy enough to do with a rented fuel pressure gauge from your local auto parts store.
Shatcher0428
Shatcher0428
I did several things, one was I had replaced the battery with one that has 800cc, also had been throwing a flex fuel sensor code so I fixed that and lastly replaced the fuel pressure regulator. It made a huge difference changing the regulator. I was hesitant about replacing because I had just replaced it 2 years ago but whenever I went to swap it out I noticed it had a bad o ring so it was sealing properly
S33k3r
Dallas, Texas
Thanks, y'all. My Suburban 1500 is throwing a P0455 code, and I don't have a smoke machine. :-( My biggest fear is having to replace the fuel pump "module".
Shatcher0428
Shatcher0428
Hey update on the stalling, I ended up replacing the fuel pressure regulator again and whenever I inspected it I notice a Oring did not seat properly causing loss of fuel pressure. I also replaced the flex fuel sensor with a dummy one. I do not use E85 nor will I. so that being said the burb is running a lot better. Thanks for everyone's help!
CrackerJack135
